Noble chisel plow wheel bearing
does anyone know what the bearing would be on a noble brand chisel plow? My plow is old and well used and I had the whole hub fall off in the field. Bearing is gone and I might have to take the other side apart to see what bearing it takes. Ideas?
Measure the spindle and the hub bore. Any parts man worth his salt can match it up from that. Or if you have the outer race they can match the bearing to that, with the spindle diameter.
If one side went bad the other side is probably soon to follow, so might as well take the other side off and check and grease it and get the right bearing number, save a lot of headaches in the long run. Gene
