Farmall 706 hydraulic relief valve
Hi there. I've got low hydraulic pressure on my remotes, not enough to open my Gehl 1310 round baler door, which makes it a bugger to get the bale out! Anyway, Redrunrite has the valve but won't reply to my e-mails, they may not ship to Canada but at least they could let me know. I have been told that the valve from a 585 will fit and boost my pressure, I believe it is 2500psi. I'm wondering if anyone knows if that is true and if 2500psi will be ok.
Thanks for now.
Get the valve from a 1466.It will be 2500. A 706 is only about 1450.The higher pressures PROBABLY wont hurt a thing.But go with a lesser pressure relief (IMHO).Something like a 856;966....Something about 2000 .Any of the 06;56;66 series tractors will work.Keep trying,Joe should get back to you. He's a busy guy.He KNOWS his IH stuff.
(quoted from post at 20:56:55 04/27/15) Get the valve from a 1466.It will be 2500. A 706 is only about 1450.The higher pressures PROBABLY wont hurt a thing.But go with a lesser pressure relief (IMHO).Something like a 856;966....Something about 2000 .Any of the 06;56;66 series tractors will work.Keep trying,Joe should get back to you. He's a busy guy.He KNOWS his IH stuff.
Original pressure in a 706 was 1600 psi with an update to a 1800 psi valve. The 2500 psi showed up after the first 86 series tractors came out.
System pressure for 786, 886, 986, and Hydro 186: 2000 - 2350 psi.
System pressure for 1086, 1486, and 1586: 2250 - 2600 psi.
The smaller tractors came with either a 2000 psi valve or a 2300 psi valve. The larger tractors came with either a 2300 psi valve or a 2500 psi valve.
Well before you get all carried away with relief valves , Did you ever think about having the PUMP FLOW RATED . If the pump can not make the pressure i do not care what relief you install .
