John Deere Model 40 - Need pushrods part number...
Tried to order these today from this website, but they don't stock them. 2 of mine were found bent on disassembly. Do I need to worry about this? Can I attempt to straighten them out on a lathe or something?
Yes, you can straighten them.Just lay them on a flat table/workbench and pound them straight.Tap till it rolls straight.Been a
lot straightened that way.No need for a "lathe" or 'special' tool.But first find out and remedy the cause of the bending
pushrod.
If it a gasoline version (rather than an all-fuel), you can still get the pushrods from DEERE (Part #M30T) but they cost about $84!
After straightening, they will never be as strong as new, but on this slow-running, low-compression engine you will probably get by with it.
40 parts catalog
2 cylinder 40 tractor or 4 cylinder 40 combine? And years ago valves stuck in the AC 60 combine engine and bent the rods, just straightened with a hamer on flat surface and ran for years. Just might have to adjust valve clearance.
