Like tractorguy I have a B & S twin that runs great but is very hard starting at 50-55 deg or so temps. You have to go thru 4-5 full choke start cycles of 20-30 sec each to ever get engine fire. Always drain gas and put in fresh at first start of season. It has a diaphragm fuel pump ahead of carburators. Question - Techron makes two types starting fluid, one less potent and another more potent for diesel engines. Have you engine guru's ever used a mild type start fluid on a small gas engine. Thinking about this for first season start for less wear on battery & starter. The engine is about 5 yr old.
