mf-65 gas-is there ports to hook up hyraulic lines?
Rkh
Is there ports on tranny to put supply line & return line for hydraulic lines to a front bucket so not to have to put a hydraulic pump on?
Neighbor has a 65, which he loves. It has a two spool valve, which I believe was a MF option. It is somehow interconnected with the three point lift. He has a loader hooked to one of the spools. It is so slow in the winter, he is trying to come up with an option. One consideration has been to mount a separate pump/system to get decent flow. I keep telling him he needs to get a Kubota!
You can add a MF valve in place of the plate beneath the seat held in place by two bolts on the hydraulic lift cover to operate a remote hydraulic circuit.
The valves are a bit hard to find but do show up from time to time.
Dean
I added a pto pump (ebay) which works great but pto seal leaks and need to be replaced for second time. It is mounted in place with chains. This is why i was asking about a place to put supply & return lines to the tranny
Try Again
I mite be interested.can you email pictures. How much with shipping to 16946? Does it work?
