There is a post below about the miles or hours between oil changes. What is a reasonable time between oil changes on very low use vehicles and equipment? My concerns are moisture contamination from condensation or blow-by, and oil additive breakdown. Some sources recommend oil changes as often as every 3000 miles or 3 months, others recommend every 7500 miles or 6 months. On a vehicle that is used less than 1000 miles or 20 hours per year I'll change the oil annually or every two years and change the filter every second oil change.
Does anyone go a much longer time between oil changes on low use engines?
Thank you in advance.
