Serial ID For 861 Powermaster and Which Engine
needing assistance deciphering serial number on my tractor and also how to tell which engine I have. First the serial question - on the serial stamp on the tractor the first line has "861" which is obviously the Tractor series model; next line has: a diamond emblem then "5056"; the third line is a dash followed by "15056" and then another dash. According to Tractor Data.com this would be either a 1957 or 1958 year but which one is correct??
Second question - the Ford Shop Manual for my series tractor says three engines were available for series 501-901; a 134 CI which was available in gas or LP; a 144 CI which says is diesel only; and then a 172 CI for gas, LP or diesel. Tractor Data.com lists three engine options for an 861 all 2.4 liter and either LP, gas or diesel. My engine is gas - but which CI engine do I have?? Thanks very much.
The 861 gas has the 172 CID engine, and serial number would make it a 1957 based on the "5056" you found on the first line. I do not know what the second line of numbers mean but somebody else will.
The 801 series ran from 1958 to 1962. Yes they did start making them in 1957 but still called a 1958 so yes you could have a 1957 built 861 but still called a 1958 just like you can buy a 2016 car in Sept of this year
