intell-power 9200
ben brown
building a mobile a shop on cargo trailer put in a voltage converter it show a ground to the frame from neg.battery and then to the power box . and also a grown from the converter to the frame. when i wired the trailer i run a hot with a grown not wanting to use the trailer as a ground. my question is do i need to ground the battery to the frame.
I would because at any time there is no chassis ground, the equipment could create stray voltages and smoke can be let out of very expensive equipment. Jim
(quoted from post at 16:29:40 01/31/15) building a mobile a shop on cargo trailer put in a voltage converter it show a ground to the frame from neg.battery and then to the power box . and also a grown from the converter to the frame. when i wired the trailer i run a hot with a grown not wanting to use the trailer as a ground. my question is do i need to ground the battery to the frame.
ok well that make sense so that what i well do thanks
