Geo-TH,In
I have 2 Kawasaki engine, 17 hp on JD lawn tractor, the other is v twin on a 4010 mule. The filter on the left came off my Farmall C. After seeing how clean that Farmallfilter was, I installed an hour meter on it.
The filter in the middle has 4 fewer pleats than the filter on the right. Both filters have metal in the center, only the filter on the right has metal on the top and bottom and a better pressure relief valve design attached to the one metal end.
So which do you think is a steins and which a Kawasaki?
