Land reclaimation plough on demonstation
WIZZO
Note the frame work for mounting the plough is along the sides of this Fordson E27N tractor.
A left hand and a right hand plough body - 1 in work and 1 out to give level ploughing controlled by the levers. Note the huge plough body, designed for ploughing in large amounts of surface vegetation and roots on land reclaimation.
You should have seen the DMI single shank chisel that was used around Farmington, IL. You could drive a pickup under the shank.
