Does anybody know what the solenoid resistance would
be on the power shift solenoids on a case 2294 or
where I might find the information
Never checked solenoid resistance but have compared amp draw between all solenoids as too much draw on one of them will ruin circuit board/controller. Use my battery/elec system tester amp clip around each solenoid wire.
The purple wire in the number 1 position is fried the solder has come off. Will the solenoids still have power if circuit board is messed up? My whole problem is tractor won't move but I still have steering and lift arms work. I parked it went back to it a week later and it wouldn't move it wants to but won't. I changed the 2 filters on the bottom passenger side but made no difference
I'd fix the burnt wire, replace circuit board and DEFINITELY check amp draw on individual solenoids before using tractor. Chances are one of them are bad causing circuit board failure.
