soldering a radiator
Nick167
Is there anything special to it? I have a hole in the radiator on my Oliver 77 I got and was wondering if there is anything special to it
...and make certain (don't ask me how I know) to use a small, localized flame or other heat source, otherwise you will unsolder the surrounding area.
My first attempt at soldering a radiator was a complete bust. I used a propane torch, and burned up a hole the size of a basketball! Had to buy a new one. That was 50+ years ago.
Gunny, in Iowa
It has to be well cleaned like Robert posted. You also have to use the correct solder. The solder you use on copper pipe is not the right stuff. Most radiator solder is 20% tin and 80% lead. Plumbing solder is usually 50/50 mix. It is more brittle and will be more likely to crack. Also the higher lead content makes the melting point be lower so you do not have to have the radiator as hot to use it.
I also usually sue a liquid acid based flux when soldering radiators. I never have had much luck with acid core solder on anything.
all depends where the hole is. if you have no experience with soldering then a rad is not the thing to practice on. its an art of its own. a rad shop would be a better choice and times they will reject them cause of the material just being too rotten.
I've done some good repairs with jb weld that have lasted a long time if you clean it good and don't use the fast set up kind
I have done a lot of repairs to radiators. Like someone said clean is your friend. I use acid flux. For the first time you may want to use JB weld. I have used it on radiator tubes that were too thin to solder, trying to save a very expensive radiator. It works good. Stan
I repair all my own radiators for the last 40 years. Always soldered them with ideas mentioned below.
About 15 years ago my skidsteer back door opened somehow when I was backing up. I somehow ripped open about then tubes. Had a rock picker on and wanted to get going. Mixed a batch of J-B Weld and packed it in. It was going to be a temporary patch. It is still not leaking today.
Since then I has used it quite a few times. If cleaned halfway good, it never will leak. Faster and a lot of times do not have to take radiator off. If I have the radiator, I solder them out of hasbit I guess.
clean, use pin point soldering tip not the general purpose tip, use tank with hose not the compact tank/tip assembly, acid flux, watch somebody solder a radiator first.
Just put some black pepper in it and run it for a while. JD 70 has had pepper in the radiator for over 6 years, if it does leak a little later on , add some more pepper. Chris
Clean as possible.
Devcon (make sure it is high temperature) works on aluminium radiators like Kawasaki KLR's
And if you're soldering be aware that there can be electrolysis problems with solder and radiators.
Never found out how you avoided these - but if it is a pinhole then that is probably not the problem. On the other hand if a big part of a seam has started to leak - - .
Don't feel bad. First radiator I soldered I used a #1 A/O welding tip and it was waaaaaay tooooo biiiiiig!!!!!
Armand
