Rotoiller rotation speed with PTo at 540rpm
With Tractor off and PTO disengaged. Turn PTO by hand. Count turns of PTO shaft per Rototiller. There are different rates. Most equipment has a tag on it.
Don't have the gearbox and drivebox. Don't even know the brand just want to make it operational with parts on hand. any intelligent guess would get me started,.Couldn't come up with anything on a web search. HELP!!!!!!!!
(quoted from post at 12:45:10 01/24/15) Trying to determine the rotational speed of a rototiller when PTO speed is 540 rpm. Are the all mostly the same?
Woods Rotary Tiller
Model TCR 74
Tilling Width 74 inches
Maximum Tilling Depth. 7 1/2 inches
Number of blade flanges 9
Number of blades 36
Drive type #80 chain
Tractor PTO speed 540 RPM
Rotor speed 240 RPM
Tractor Horsepower up to 45 HP
Typically the more the blades and slower a tractor will travel the slower the rpm and HP can be. I use a Howard Select-a-Tilth set at its highest speed (not sure what it is) and it has 6 teeth per flange (3 on the ends). My tractor does not have a creeper gear, but I have more than enough HP to get the job done faster.
