I am helping a fellow on a Ford 7.8 liter Brazilian made Diesel motor. It is leaking around the barrels. When I looked closer at the pump I am pretty sure the housing is corroded where the barrels seat. So a seal kit may not Fix the problem. I am wanting to find a remanufactured pump to just exchange.
I am not find much out by application. The tag on the pump is not very clear to read. I have got some numbers for sure and others just maybe.
The number that is stamped into the side of the pump that I am 100% sure of is: 950 18855.
Then down in the right hand corner there is: RM2 stamped that is very clear.
Then printed on the tag is P??OA720 RS.
The two ?? marked letters look like W O but they are not very clear.
None of these numbers say what they are like model, series or serial number. I am not familiar with inline Bosch pumps to know what else to look for.
So do any of you fellows know which of these numbers is what I need to look for on a different injection pump????
A fellow that is pretty good on the rest of the engine knowledge on the 7.8 told me that this is a tractor derived/designed motor. Neither of us know if this engine is used on any Ford tractors.
I know that this engine was used in the US from about 1985 to 1999. They are not a power house but a pretty rugged motor. I see them in a lot of dump trucks.
