I have worked in large industry with many different type pumps.
One of the simplest pumps I have ever worked on, is chainsaw oiler pumps.
Most are a tube with a close tolerance solid shaft inside that has a shallow flat machined across the outside diameter on the end and is rotated by a gear. Inline with the flat, on either side of tube, is a feed fitting and a discharge fitting.
I have never understood how, when the shaft is rotated, they can pump oil from the oil tank to the chain and bar, with no check valves of any type involved.
