Gelled anti-freeze
showcrop
yesterday I got an old car down from the pallet rack where it has been. I was surprised to see from the plate that it has been up there for twelve years, LOL. I went to drain the coolant and found that I needed to vent it. When I removed the cap from the top of the T'stat housing there was gelled antifreeze under it. I got it mostly cleaned out and removed the upper hose. There was none in the hose. The housing and the head are aluminum. I hope that it is not all through the head. Any ideas what? how? Why?
I haven't had any leaks to stop, and the color appears to be a correct yellow green, too light to have had any red mixed in. Thnks.
I have seen that happen with cheap ethylene glycol but not Prestone or any name brand. I had an off brand bottle of the green stuff that gelled in the bottle after several years on the shelf.
My garage smelled like a mouse had died. I looked
all over for a mouse, no mouse. I had a small
coolant leak from water pump. Not enough to leave a
spot on floor but enough to smell. Yep, the
antifreeze had a moldly/dead smell. It may have
been about 5 years old.
This may be a good reason not to use antifreeze as
tire ballast.
When I was in Germany we haul trailer loads of
prestone antifreeze from a warehouse and the temp
was in the 20's. It was all just slush in the cans.
Never saw that before. This was straight anti
freeze
Ethylene is a plastic precursor with sugar like compounds holding it as a liquid. It can polymerize into a solid/jell with time and evaporation. Jim
High silicate antifreeze will turn to a green gel with age. I have seen it around cylinders to where it looks like green Jell-O. Older formulas recommended the anti freeze be changed every 3-4 years.
The silicates are there to help different metals from corroding. I was taught it was mainly better for engines with aluminum parts. I had been told that you do NOT want to use it in diesel engines. JD actually told us it could void the engine warranty.
I have had fairly good luck with using Gunk antifreeze flush to dissolve the gel out of a motor. Remember to really flush the Gunk product out of the motor well when your done.
When refilling use distilled water not common tap water. Hard water is not good for a engine's cooling system.
(quoted from post at 07:07:02 12/21/14) When I was in Germany we haul trailer loads of
freeze
That's because there was no water in the anti freeze.A50/50 mix of A/F and water will give you a freeze point of about-40 degrees or so.The water must be there to keep the A/F from jelling or freezing.
