Wagonmaster
New User
9N with 12 volt system problem. Quit running. Mechanic found electric short burn at rotor cap.. Replaced cap, points, rotor ,condenser. Would not start. Replaced coil. Still not start. Replaced rotor, condenser, points. Started but run very rough. Rechecked everything even set timing as called for in manual. Would not even start. Any suggestions? Prior to problem, had a small fire from overfill of gas tank. Put out fire with powder type extinguisher. No burned wires. Tractor ran fine for 2 hours after incident and then quit. Could powder affect engine/ignition? Have thought about going to electronic ignition.
