farmall m governor
No. If you are having trouble getting it off due to gear not wanting to come out of the hole, just keep trying and it will come off. They can be difficult at times.
Did you remove the bolt located behind the governor in-between the block & governor?
You need an extension on your ratchet & socket to remove it.
