My Yard Sprayer Pictures
John B.
I wanted to post these a few weeks ago but realized I never did. My Uncle gave me this JD tank and gear pump. I put it on a frame, hooked a B & S 2hp engine to it, installed an electric solenoid valve, put some old corn planter wheels on it and away I go to spray my lawn for broadleaves. The frame work can be taken off the running gear and the sprayer can be put in the bed of a pickup truck and just plug it into my 4-prong flat plug and operate the boom with my headlight switch. I have two flood nozzles on the short boom that will spray 13ft wide plus I have a spray jet nozzle that will spray up to 30ft wide then I have a hand gun plumbed in too. All of them have the banjo type couplings on them so I can disconnect and plug if not being used.
I drag a hog panel wrapped with chicken wire to help turn the leaves of the plants over to get good spray coverage plus I hope the chicken wire scars the leaves to get a better kill on the dandelions and white clover. The panel even flexes with the ground contour also as can be seen in the last picture in the swail.
John What chemical do you use.. 24D? or what? Cool wet spring and I had more clover than ever.
I use 24D with a little liquid dish detergent. Clover is hard to kill.
I found out that regular fertilizer is the easiest way to kill clover. The grass will choke it out. I haven't tried that yet but will try a little test plot next spring.
I belive you did post these a few weeks ago! This is the 2nd time I have seen them, but they are worth seeing again! I built a sprayer, a lot likr yours, after removing the shanks and shovels from a Fergeson 3 pt. cultivator, and mounting a 55 gal plastic barrel on it, with booms, and using a PTO roller pump. Valves and pipe fittings were the most expensive components, other than the pump.
Does the harrow help ? Have you tried it without it looks like a good idea might stress the plant and make it from taking in more chemical
Yep I agree. The harrow hurts more than it helps.
He is also dragging the spray around and not leaving an even pattern.
As farmers we spray thousands of acres and are taught to stay out of the fields for a few days to allow the spray to do it's job without disturbing the plants to put them in a defensive mode.
Gary
Nice looking home made sprayer.
I don't understand why you need to pull the panel behind it though. I would think you would get a good kill without it.
I'm glad you posted the picture though. You gave me a good idea on a drag for the baseball diamond at my church.
Never thought about doing that with a trailer plug. That's a simple and easy thing to rig up, not only for a sprayer but anything the imagination can think up. With a little fabrication and a relay, that light switch becomes pretty powerful. I'll file that in my good idea list of things to do sometime!
