I googled the problem and it said to replace the MAP sensor. $60 later and the problem is still here, if not worst. It will barely idle sometimes and sometimes it works perfectly. To get it to run, when this problem occurs, I need to give it some gas and use the left foot on the brake to shift it from Park and if I am only backing out of the garage, I need to keep giving it the extra gas and still brake with the left foot, or it will die. Yesterday I drove 150 yards down my road and it died when I let off the gas to go around a tight curve. Not good at all.
Any suggestions?
Thank you
SDE
Any suggestions?
Thank you
SDE
