John knebel
New User
i am having a tachometer problem. When you first start on a
low idle the tach goes up to 6000 rpms. And the needle
fluxuates between 5000 and 6000,does that mean it's bad?Or
is there another issue
Is the tach electric or cable driven? If cable, it is probably dry and needs to be lubricated.
Don't know about the electric, but the first things that I would check are all ground contact points in the circuit.
The stock tach on that tractor only goes to 3000.That being said the green wire on the alternator is the tach.Good Luck.
