Anonymous-0
Hey folks.
Took the advice of some folks on here and a couple other forums and have been adding about a half cup 2cycle oil to the tank of fuel in wife's Kia. Seems to run quieter and smoother and you can tell a difference if you run it empty and fill it without adding (after a couple hundred miles).
Anyway, been using normal 2cycle oil (non synthetic). Wife ran across a forum that said you have to use at least a synthetic blend or the normal type oil will clog injecters. Anything to that? If so, should I run a treatment thru now and then to clean the injecters?
Thanks, Dave
Thanks, Dave
