RV anitfreeze as tire ballast--revisited
Mike(NEOhio)
Location
Newbury, Ohio
WOW guys, I didn't intend to start a war, here. Thanks for all the opinions, good, bad or otherwise. Now some of mine.
Ethylene glycol is toxic and has a sweet taste to animals. I don't know what the new non-toxic stuff uses. Maybe propylene glycol. They put that in ice cream to keep it soft. Like ethanol or methanol. One is happy water, one will blind/kill you.
Chloride salts are all corrosive. Hose down the wheels often. I even put a little anti-sieze on the stems when I have them out.
Don't know anything about Rim Guard or foams.
Most of my tractors are from my FIL and about 2/3 filled with CaCl since the 50's and just showing some heavy rust. But he did replace both rims on one about 30 years ago. I only make hay so I don't really need all that weight. Where would I get rid of all that solution, anyway.
And I did get a bigger tractor this year. It's heavy enough without ballast.
Always fun to hear opinions and stories, eh?
Hi Mike you could call a Tractor tire service shop and they could pump it out for you or there are other ways you can do it yourself, just Google calcium chloride disposal there will any number of sites and suggestions.
GB in MN
Pull the valve stems and let er fly ! That's the way I got rid of mine. As said before a fence row is a nice place for it. You won't get it all out though. I then like to put in new tubes and paint the rims inside and out.
On the rim gard it is pretty expensive and hard to find anyone to do it. Most tire shops tried it and don't like it because in cold weather when doing repairs it is hard to pump out because it gets thick.
On your "new" tractor hard to say as it depends on what you want to do and if you have a front end loader or not. If you have a FEL you HAVE to add plenty of counter weight on the rear somehow.
Mike, Ask around and you may find another farmer in your area that will come and pump it out for you if they can have it. I know that some around here are glad to get it. David
Rim Guard is just sugar beet juice. Good to 35 below F and costs round $1.50 per gallon. No rim rust and not tire valves rotting out. Just a sticking mess if you get a leak. Here in northern Michigan, during big game hunting season, there are huge piles of sugar beets all over the place. If you had a way to make them into juice - it would probably be 50 cents a gallon.
