DaninKansas
I have an issue with the front brakes on my 1997 F150. It has about 123,000 miles and is in pretty good shape. The problem is the front brakes pull fairly hard to the left under moderate braking. If you step hard on the brakes the pickup pulls to the left for an instant then "evens out" with no pull to either side. If you "pump" the brakes the pull isn't as bad but its still there.
I thought I had a pad or air in line issue but when I replaced the pads they actually looked to be in good shape. I also bleed both calipers hoping to find some air but I didn't. I replaced the pads with no difference in operation.
The brake lines look OK - sticky caliper issue?
