MF 135 Multipower shaft sealing rings
I am trying to locate the sealing rings used on my MF 135 w/multipower. The MF part numbers for the PTO input shaft as well as the transmission input shaft would be greatly help in locating the correct rings.
Any help?
Thanks, John
Seal rings for the transmission shaft, 186 581 M91, for the PTO input, 186 198 M91. You will need the trans code # stamped next to the safety start switch as the shafts have changed over time while the seal rings were never changed. Look inside the PTO input closely, it will need replaced if the rings have worn deep grooves inside. The ring end locks will only let them expand so much.
DT, thanks for the info, The shafts have a slight groove but will still be usable. Not deep grooved as have seen before.
John
