Mounted a 60s vintage Myers snoe plow on my tractor.
Adirondack case guy
I bought this plow from a former Case customer earlier this month. It was originally fitted to a 57 Case 300, and then modified to fit on a MF 165. I cut the frame apart and reconstructed it to fit my Case 440.
I also bought a ROPS canopy at an auction, new in box, which was built for Cub Cadet side by side, and Fabed up some mounting strutts for my 440 and bolted it fast.
I am in the process of building a mod 3pt hitch for the rear.
Loren, the Acg.
We used to sell Meyer, I had an n.o.s one, the frame and blade for quite some time, long frame for a tractor mount if I recall. I remember it was a manual angle. Tractor is getting a nice retrofit !
Side curtains on the list?? After many years plowing out in the open I bought a truck with a plow and have had one ever since, heat is great!!!
Yes, I have a salvaged windslield and rear window with rubber moldings from a Case 70 series tractor cab which I plan to install into the canopy. I will build bolt-in frames with the glass in them, so they can be removed in the summer. I have some 20g steel which I will fab engine side curtins, to push the engine heat back to the operator area. Still working out the details on the sides of the enclosure.
Loren
Nice looking setup. You'll want chains on the rears, and be careful because front will want to slide, not steer. Don't ask how I know.
I bought a brand new set of double ring chains that were buried under a bunch of junk on a pallet at an auction. Payed $10 bucks. Can't beat that with a stick!!
Loren.
