looking for mstr and slave cylinders or replacements d450 3040742 ser # anyone know of the following and current sources for them
this was in this forum I think 2006
brake best master clynders part number MC39626 48.50 each are the ones i used good match bolt right up only need to put an adapter in the in out put line to fit brake line wwwequipmentpartssource.com parts sources in wy have the slave cly for 47.00 dollars. i like you the brake need to work and it not a big deal to replace disk. like i said before you can use meteal line to replace the rubber ones with a little bending they work fine and a lot cheaper
and a new contact for equipmentpartssource?
Joel Lansy 313 215 6859
