Christopher S.
My wife drives a 2008 Lincoln MKZ with approximately 62,000
miles on it. This car is basically the same as the Ford fusion
or a Mercury Milan. A little while ago I was driving it and had
to do a panic stop because of turkeys crossing the road, I
thought the brake pedal was a little spongy afterwords but
didn't mention it. My wife has started commenting on it and
she wanted me to get it serviced so I took it to a local garage
that had the appropriate scan tool to cycle the ABS brakes.
He said that without a doubt the hydraulic end of the ABS
control module needs replaced, it is not a take apart and
repair item it as a whole unit.
His description of what happened goes like this. When you
use the brakes in an emergency situation and a wheel locks
up the computer tells this valve within the ABS module to open
up and release pressure. This valve opens and closes
repeatedly creating the ABS feeling in the pedal and allows the
locked up wheel to turn. If you have not use the ABS function
in a while the Valve can get sticky and tear the seal that it goes
through. This prevents the valve from returning to it's closed
position and now gives you The spongy break feeling we are
noticing.
If you give it time the valve seems to close and you regain
brake pedal feeling again and everything is normal until the
next ABS situation panic stop.
The hydraulic control module that I need cost about $1000 and
an additional couple hundred dollars for the labor. The
problem is the part is on national backorder and they don't
know when it will become available. We are getting into snow
and Ice soon, I fear that the part is not going to become
available when she needs the ABS brakes to be working.
Do you guys have any suggestions on the situation?
Could I pull the ABS fuse from the car so that the abs control
valve never opens but she no longer has any ABS function at
all?
Should this be some type of warranty work the Ford garage
said there was no recalls or statements issued that it should
be.
Thanks guys
noticing.
all?
be.
Thanks guys
