Bobthefarmer
New User
Learn so much from this site.
So on the ratchet nut on the front pulley, is it
Righty tighty and lefty loosey? I'm adding a threaded shaft to power a hydraulic pump on front. I know it's torque is 150lbs.
Thought I'd ask before heating, spraying and pulling on a breaker bar. Thinking it would be cheaper to add the threaded shaft rather than buy a pulley, splined adapter, nut and new shaft. Gonna pull the front axle away and remove radiator and sheet metal. Adding a new pivot pin too. Any suggestions or advise would be welcomed. Thank you.
