JD 5055D Tell Me About It
Spudm
Local JD Dealership has come down to a price of $14,350 on this new 2014, two wheel drive, utility tractor, which includes delivery. It is rated at 55 engine hp. It includes oversized rear tires (16.9x28).
I would like to hear Pros & Cons about these tractors for use around a small farm, like pulling a 14' transport disk on hilly sandy soils, and a one row pto potato digger. Thanks!
I would sure consider 4wd in a tractor of that weight and power class. Especially if you will ever have a front end loader on it. Also very useful with tillage implements in loose soil conditions.
FWD is nice but if you are going to use it in tight places, they do not turn nearly as short. Keep that in mind when making decision.
I bought one about a month ago. If you take the cash deal, there is a $2,500 rebate from Deere. That is what I did and got the tractor for $15,250, including the larger rear tires, fluid and delivery.
I cut, raked and baled about 400 square bales - so far, so good.
Basic, no frills tractor.
When I bought mine I was not color shopping, though I wanted to stay with older line brands for the dealer support. Kubota was out from the start as I didn't care for the dealer. That left Massey Ferguson, New Holland and John Deere.
I wanted a tractor with higher clearance for straddling wind rows and enough power to make a 4x4 bale one of these days. I also wanted parts support long term as I'll use this tractor and my boys after I retire/expire. The MF 2615, NH Workmaster 55 and JD 5055d were the choices.
The MF was lower to the ground and has a Simpson diesel. I'm sure nothing wring with the Simpson as I'm told it's a Perkins clone, but when I google, don't see much in the way of parts. The NH is a nice tractor, but the dealer him-hauled around about if he could get one and the price was the highest of all three choices. It has a Shurabura (sp?) which I think is a good engine, but not sure about parts. IMHO, the #1'reason to buy the Deere is the 3029 engine. In my day job, I have experience with this engine in generators. They are durable, high hour engines and lots of parts everywhere. The basic design of the 5055d has been around for 20ish years. There are some problems I've read with melting fuel tanks from hit castings nearby (from a hydraulic problem), but from what I can glean, it is on the 9/3 tranny tractors vs the 8/4 in the 5055d. Also some of these tractors have some brake return springs internal to the rear end (as I understand it) that can be problematic, but that is with hydraulic actuated brakes. The 5055d has mechanical brakes.
If you buy the tractor, have the dealer put it on a dyno to seat the rings and pay attention to the manual for the first 100 hr engine break-in requirements.
Good luck,
Bill
A 14' disk on hills, with a 40 something hp tractor???
I am using an honest 100 Hp tractor on a 14' disk, and find myself wishing for more when it comes to a hill.
We have à 4320 compact JD. It is 4wheel drive. We use 4wheel drive almost every time we use it. Have over 1000 hrs no problems.
I couldn't make any speed pulling a 14 ft disc with 70 HP after the first pass on level ground.
A 14 ft disc on a 55hp tractor? Nothing like severely overloading a tractor. Knock about 5 ft. off that disc and you will be in the ballpark.
