Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Bush Hog on Farmall Super A
John Healey
08-07-1998 12:50:13
A while back there was some discussion about the use of a bush hog on a Super A . If any of you guys are running a bush hog on a Super A I have a question for you . How do you deal with the high off-center PTO shaft of the Super A. Is this a problem or will universal joints handle this much offset ?
pete
08-10-1998 18:21:16
 Re: Bush Hog on Farmall Super A in reply to John Healey, 08-07-1998 12:50:13
: A while back there was some discussion about the use of a bush hog on a Super A . If any of you guys are running a bush hog on a Super A I have a question for you . How do you deal with the high off-center PTO shaft of the Super A. Is this a problem or will universal joints handle this much offset ?
John: I've been using my Super A with a 4 ft bush hog and I have not found the high offset PTO to be a problem. But,I do have 3 pt hitch on the tractor so that keeps the PTO shaft from swinging when making a turn. Everything seems to work fine and it has plenty of power (I don't have any direct experience with the "trailer" type of bush hog, but I believe I've seen some companies liturature indicating that their trailer type bush hogs fit a Super A and that would seem to say that the high offset PTO shouldn't be to much of a design or operational problem )
Pete
John McDevitt
08-07-1998 13:23:18
John,
I recall the discussion, in fact I asked the follwoing question at that time: "Do you have any problems using rear-mounted equipment with the Super A's 'offset' pto due to the angle?" I couldn't find the actual response but the answer was that there was no problem. Perhaps whoever brought this issue up several weeks ago will see this posting and provide an update.
John McDevitt
John Healey
08-07-1998 15:04:07
 Re: Re: Bush Hog on Farmall Super A in reply to John McDevitt, 08-07-1998 13:23:18
: : A while back there was some discussion about the use of a bush hog on a Super A . If any of you guys are running a bush hog on a Super A I have a question for you . How do you deal with the high off-center PTO shaft of the Super A. Is this a problem or will universal joints handle this much offset ?
: John,
: I recall the discussion, in fact I asked the follwoing question at that time: "Do you have any problems using rear-mounted equipment with the Super A's 'offset' pto due to the angle?" I couldn't find the actual response but the answer was that there was no problem. : Perhaps whoever brought this issue up several weeks ago will see this posting and provide an update.
: John McDevitt Thanks John , I'll wait and see. I also wonder what is the best size for the Super A , 4-foot or 5-foot.I don't plan on doing a lot of bush hogging , just clean up after the fields are mowed . Probablt the 4-foot would be my best bet.
Greg Martin
08-07-1998 16:55:09
 Re: Re: Re: Bush Hog on Farmall Super A in reply to John Healey, 08-07-1998 15:04:07
: : : A while back there was some discussion about the use of a bush hog on a Super A . If any of you guys are running a bush hog on a Super A I have a question for you . How do you deal with the high off-center PTO shaft of the Super A. Is this a problem or will universal joints handle this much offset ?
: : John, I have a super a and use the brushhog every week. It is 5 ft, Iinstalled a overrunning clutch on the pto I have no trouble at all , probally the best small tractor ever built, with 2 hyd lift points what more could you want. When I come to the end of a row to turn, I disengage the pto & engage when I get turned around,the ujoints do work hard on LH turns, thats why i release the pto.
The ujoints on mine do not have needle bearings in the cups so I have to grease them each time I use it.
: : I recall the discussion, in fact I asked the follwoing question at that time: "Do you have any problems using rear-mounted equipment with the Super A's 'offset' pto due to the angle?" I couldn't find the actual response but the answer was that there was no problem. : : Perhaps whoever brought this issue up several weeks ago will see this posting and provide an update.
: : John McDevitt
: Thanks John , I'll wait and see. I also wonder what is the best size for the Super A , 4-foot or 5-foot.I don't plan on doing a lot of bush hogging , just clean up after the fields are mowed . Probablt the 4-foot would be my best bet.
