Help with clutch problem
StevenT
New User
Good day folks.
I have an old Kobuta B6100E.
I've had it for years and it owes me nothing.
A few years ago I had a new clutch installed and it operated fine.
I seldom use the tractor and probably have around 20 hours on the new clutch.
The tractor has been sitting for about a year or so and now when I try to use it, the clutch does not disengage the drive.
I start in neutral and can get it in gear but the clutch does not disengage the drive.
Any suggestions?
Thank you
Common problem with most any thing with a clutch. Get it out into an open area and then start it in gear the highest you can and take it for a drive. Hold the clutch pedal down as you drive it. Tap on the brakes can also help some. Be ready to drive it till the engine has warmed up real good. Also when you park it block the clutch pedal down so it does not happen again
What causes this? This just happened to an old truck we had parked for a few months. It broke free and is fine now, but I'm having trouble figuring out what rusted to what to cause this to happen.
The clutch disk has metal fibers in it so they rust tight to the flywheel or pressure plate and stick
Seems llike I thought the metal fibers were brass or bronze. They ought not to rust themselves to other metal, I would think.
I always thought the sticking was due to a collection of grease that hardened and stuck things together. Might be wrong.
Not a tab on that one but it came with a small short wood block that no one ever uses but it cures the problem. Mash the clutch and put the block in place when you park the tractor. As for getting it un stuck, as the others have said load the unit try and get in a higher gear and drive around with the clutch pedal mashed or cycle it up and down. Soon as the tractor warms up usually will come loose. AFTER you get it working hold your foot on the clutch and just let it try to engage or slip the clutch for just a short time, will help polish the pressure plate.
I would say that from this coming up probably 25 times in thirteen years that it is due to humidity.
Yes.
BTW even if the fibers in the disk are not steel, the flywheel IS steel. The rust that forms on the flywheel works its way into the microscopic gaps in the surface of the clutch disk.
If your bellhousing has a inspection hole or cover,lock the pedal down and take a long screwdriver,and work it between the disc and flywheel,doesn't take much to pop it loose.
