cs.hess
Electrical question similar to earlier post.Is a 1500 watt 220 volt baseboard heater cost the same to use as a 1500 watt 110 volt heater? Cost here is 15cents per kw. Or while they are both rated 1500watt would the 220 volt produce more btu?
Cost the same to run. Cheaper to wire in 220v. This is assuming no loss in the wire to resistance losses.
No been around long enough to know you cant beat system!I been roaming sites an near as i can tell both of the heaters will produce 5100 or so btu. So i gather 1500 watt is electric used an am i correct in thinking that would be one an a half killowat per hr an would cost 15.38 cents per hr --$5.53 per day--$166.15 per month assuming on constant.
No i been around long enough to know you cant beat system!
I been roaming sites an i think they will both produce 5200 btu. i think you are saying they will both cost same to operate.Am i correct in thinking both will use one an half kilwatt of current at 15cents per hour or$5.50 per day an $166 dollars per month assuming there on constant.
(quoted from post at 19:02:37 10/01/14) No i been around long enough to know you cant beat system!
I didn't do your math, but sounds about right from my bills last year when I started using them when propane topped 5 bucks.
Old house here, so I buy them 2 at a time.
run each at the 750 low setting.
same cost and heat as one at 1500,
less loading on old wiring -different circuits-
And I don't trust those import cheapy heaters at max anyways.
They always smell like they are melting/burning on high.
Electric is 100% efficient at the household end. No mater whether it is a $25 milk house heater or a $300 Amish built one.
That should start some discussion.
well, true it is 100% efficient. However resistance heat is the most expensive heat possible. Pay for 1 kw electricity, you get out 1 kw of heat. Friend of mine has learned that the hard way. If you have almost any sort of heat pump, pay for 1 kw of electricity, you get far more kw out of the outside air.
