Day 2 of Antique Engine and Tractor Assn Fall Show
super99
Started out cold, ice on a couple of golf car seats, club member across the road from show grounds said his garage roof was white this morning. Warmed up quick, good crowd today. I plowed some in the morning and after lunch I changed over to the picker sheller and ran some corn thru it. Was working great until we were almost finished with the field we were in. I ran the outside snout on the Oliver 73 into a mound of dirt and rolled the snout back under the picker. A club member and his son(Thanks, Charlie and Parker) helped me get the snout off and I hooked onto the plow for tomorrow. Golf car started acting up, won't run at slow speeds and backfires sometimes( I thought I had that fixed, ran great at home and Friday). One more day to go, weather sounds like it will be a good day. Chris
Sounds like a good show Chris. Sorry for your troubles! I rolled the outside snout on my #5 two years ago and broke the cast chain gear at the top.
What do you pull the 73H with? I'm looking at one but would have to use a 77 or Super 77.
Sorry, no pictures, it takes this computer about 10 minutes to load 1 picture. Go to the website in a few days and there should be pictures up; www.ae-ta.com
I have a 88 with a 77 gas motor in it that I use. It handles it well, but you know when the wagon is getting some corn in it. I have a 73 parts picker, but the same snout is booggered, have to see which one is easier to fix. Where the bottom sprocket bolts on is bent some, think I can straighten that OK. I have until next September to get it fixed. Chris
