Farmall 560 Hydraulic
mdb8875
New User
The hydraulics stopped working and I assumed it was the pump. When I removed the pump, the gear that runs the pump, would move on the shaft. Looks like it would move enough to not allow the gear to engage the hydraulic pump. I have been unable to find any information on the gear. How to remove, how it is attached, etc. Looks like there could be a nut missing that would hold in place.
Any help would be appreciated. I have pictures if you would like to review.
Thanks
i just had the same problem on my 460. the gear is held on with a bolt accessed through clutch opening on bottom and large pipe plug in rear of clutch housing. should also be a large thick washer under bolt. torque 100 ft lbs use loctite.
