hit and miss
brandon j
My 6year old boy has expressed interest in them but I don't know the first thing about them would like to know what would be a good one to start with I don't want to get a money pit thanks for any help you can give
Lots of tractor shows this time of year have displays of them, and I"ve seen many for sale. Don"t remember prices, but didn"t seem too steep. And if it;s for your boy, price doesn"t matter.
First of all, not all "open flywheel engines" are "hit and miss", many are "throttle governed, in a similar fashion to modern industrial/ag engines.
So if you just search for "hit and miss" engines, that will leave many out.
IMHO, to start out with, probably the most common open flywheel engines you will find are IHC, Fairbanks Morse, and various versions of engines made by Hercules Engine Works, Sears/Economy, for example.
Here's a couple of links...
http://www.gasenginemagazine.com/
http://www.hitnmiss.com/
(They deal with throttle governed, as well as "hit and miss" engines.)
There is a stationery engines section a little further down the Forums list. P.S. I have one and it is simple and fun. Caution with youngsters around the open flywheel.
go out to you tube and check out shopdogsam. One of his video series is a complete rebuild of an IHC engine. It is pretty long, but you have a very good understanding of them by the end.
Yes, the JD model E is a good starter engine.
I just got a 3 hp E running today for the first time in 60 years. We wanted it to do something, so it is mounted on the rear of a purpose built 3 wheeled motorcycle parade toy. Front fork / mag wheel, front frame is a 400 Yamaha, seat is a steel plow seat, rear axle is a Ford 8 inch with ET mags with 10 inch wide tires.
The model E engine, being JD, exhausts into the mandatory 6 inch X 4 ft chrome stack. Transmission is a 48 Ford truck 4 spd crash box.
Will run it at the local threshing show next weekend.
