Deutz 8006 help
Bought a deutz 8006 yesterday. Tractor data says
it has 16 forward gears.One shifter has 1-6. The
other one has 4 selections one reverse and 3
forwards but no knob or labels. There is another
lever behind these with 3 positions that goes into
the side of the tranny,what does it do?
the left stick is a high low and reverse. the right stick is 1-6 forward 6th is locked out on reverse . There is 4 positions on the left stick but 2 of them are actually the same speed there is also a creeper lever down in front of the seat. the lever on the left of the trans shifters is for the pto. nuetral in center. 1000 rpm forward and 540 back
Thanks very much!!! I been driving it around in circles this morning thought 2 of the positions on the left stick were the same and kinda figured the one in the back was a reduction of some kind. The knob is gone off the left shifter and markings gone off the back one.
You also should have a big lever that actually works the PTO clutch. Your supposed to kick the PTO speed shifter into neutral and engage the long lever so the PTO clutch bearing is not running under load all of the time.
I had a DA 7275 it had the PTO set up like this but without the 1000 RPM option.
