help I need a pulley for a 112 John Deere mower deck. Need the double pulley for the deck and maybe the shaft and bearing. shaft has roll pin.
(reply to post at 16:59:58 08/25/14)
To get the correct pulley one needs to know which mower deck you have.
(quoted from post at 13:59:58 08/25/14) help I need a pulley for a 112 John Deere mower deck. Need the double pulley for the deck and maybe the shaft and bearing. shaft has roll pin.
D dealer has them $$$,...It might be cheaper to buy a new deck!
Likely, the parts you need are still available from DEERE.
You didn"t state the model of the deck, likely it is a "39" or a "47".
You can surf over to www.jdparts.com and open that parts catalog and see part drawings and part numbers. (PC1082.)
If you sign up with a nearby dealer you can view parts availability and price.
Or, take the part numbers you find in the parts catalog and GOOGLE them for sources, or call a nearby dealer.
Pulley's from JD
AM38140 Pulley - PULLEY, SHEAVE, W/BEARING ASSEMBLED ADD 60.70 USD
AM37612 Pulley - PULLEY, JACKSHEAVE, W/BEARING ASSY ADD 153.34 USD
Rubberwrench. I don't have any JD 112 parts left. They got so cheap that you can buy an entire mower for $100-150 around here.
Thanks for all the reply's. Could not get parts diagram for deck to load from john deere. local dealer tells parts not available .Will try to find different source.
(quoted from post at 06:42:02 08/26/14) local dealer tells parts not available .
Evidently your local JD dealer parts personnel need some lessons in looking up older equipment parts because the parts you asked about are available from JD
