1. It wasn't bad antifreeze.
2. It wasn't bad head gaskets.
3. It wasn't a bad intake gasket.
4. It wasn't clogged radiator fins.
5. It wasn't the thermostat.
6. It wasn't a clogged line between the heads.
7. It wasn't the temperature sensor.
8. It wasn't the gauge cluster.
9. It wasn't an overheating tranny.
When I dropped the serpintine(sp) belt I noticed drag/slipping marks on the fan blade metal wheel. Under a load the bearing in the water pump was hanging up. I had the choice of a rebuilt pump or a new pump. I went with the new pump and the problem is now gone. Thank you all.
