J.Wondergem
Location
Rockford, Mi.
I do have a crank shaft rod and bad piston assembly. Do you need anything else like timing chain slack adjuster or bearings ? Or you can call me.
Just the piston is bad.
I bought a new slack adjuster,but the chain probably should be replaced. Maybe even the top sprocket. Do you have that and anything from the top end? I don't know if I bent a valve when it slipped the last time or not. I wouldn't know about the bearings unless I tore it all the way down and I haven't yet. Drop me an email if you've got a price.
The head and everything on top were gone when I got it. I have the chain and bearings, which I'll have to check out. Rod bearing seems good. I'll go to classic view, and see if I can find your e mail.
If you have the head off, you could spin the valves and see if they're bent, and look at the top of the piston.
