Anonymous-0
Can anyone tell me why a new water pump housing on a
JD 620 will not give me the clearance between the
pump and the main tractor casting? I bolted my old
pump onto the radiator tonight and I have a good
3/8" clearance from the bottom of the pump to the
main tractor frame. The new pump only gives me a
.067 clearance and this is with a 3/16" shim under
the radiator. I really need to remove the shim
underneath the radiator as the hood is pushed up
against my steering shaft.
