Looking for a part
John Roe
New User
Hello I have a Davis 101A front end loader on my Case 430. A bolt came loose causing the hydraulic pump to twist and one of the mounting ears where the bolt fastens the pump to the tractor broke off. Now I need a pump and find they are about $600. The pump is fine but I can no longer mount it. If someone had an old pump that didn"t work and could sell me the half of the housing with the mounting ears I could transfer my parts over and be back in business. It is a Vickers Vane pump V210-81D-12-LH. Thank you in advance.
Broken cast aluminum?
A friend hit my front pump with junk he was lifting with my tractor. Broke it right out of both ears. I cleaned up good and JB welded it. Has held for 10 years now.
You can try the other suggestions and have the ear welded back on, and that should work as long as the housing doesn't warp from the heat. That said, if you got that route you'll need a seal kit, because you don't want to try to reuse the old seals. Ever pump I have ever had apart, be it a Vickers vane, or otherwise, the seals have already taken a set and it's not unusual for them not to seal the second go 'round.
That said, try the two links below. The first has a lot of stuff, but the second seems to be geared more toward the older stuff, so they just might have a good, new pump for you, or one that has been damaged that you can get the needed part off of.
Good luck.
Precision Fluid Power
Proactive Fluid Power
Vickers vane pumps of that era are NOT AL_U_ME-NIUM!
The pump body is good "ol cast iron and re-attaching the mounting ear is NOT rocket surgery.
A V210, is in the V200 family of Vickers pumps.
It has an extra bearing in the nose, so that it
may be side loaded, such as with a belt drive.
Parts should be still available, but a new nose with 2 bolt SAE mount may not be cheap.
For parts try either of the 2 highlighted sources
in the answers to your post.
Thanks for all the help. I am waiting for call backs from a couple weld shops and looking into getting a replacement housing. I am concerned about the welding deforming the housing but I will see what the welders say. If welding wont work I might try the JB weld method before spending hundreds. Nothing lost I JB fails but a lot gained if it works.
