After using the PTO for the first time, shutting down and then attempting to start the tractor up right away again it would not start. Checked PTO switch, all fuses and safety switches and battery. All Good. The filters are all clean and fluids are good and there is no indication of any leaks. When turn the key on all the indicators are fine with no obvious warning indicators or anything. But, when depressing the spring key to start nothing happens. No cranking or sound. Nothing. As if there is no battery or line connected to the starter. It's a brand new tractor and the dealer is stumped himself.
Any suggestions or input on this would be appreciated.
Thank You.
Thank You.
