4020 weight help!
Darned Deere
New User
Does anyone know the pall park weight of a 4020 gas, narrow front with 18.4 x38 on stamped steel wheels. Thanks for the help!
I have looked at tractor data. Doesn't take into consideration stamped steel 38" wheels or say if the posted weights are for a wide front or narrow front.
If you need it that accurate you might want to weigh the tractor at the local grain elevator, etc. Good luck. Paul
A wide front gasser is about 8359# from JD. Figure something less for a narrow front and a few more lbs for the stamped wheels plus anything else it loses along the way.....
18.4x34 tires loaded with calcium solution to the top edge of the rims on cast wheels, wide front, one set of front end weights, 7.50x15 front tires, just a few pounds over 10,000.
