exhaust manifold
Anonymous-0
I just got a Farmall A and the top of the exhaust manifold is broken off.I have been checking on line for another but can find none like this one it has a damper on top between manifold and exhaust pipe. does anyone know what this is.
What you have is a exhaust lift accessory. It was used to lift implements and attachments with a large pressure cylinder mounted on the left front side. (they worked and saved muscling them up by hand. If broken, finding one might be tough. A standard manifold will work well. Jim
thankyou for the info. I grew up on a cotton farm in west texas and always said I wud never be a row cropper so I will do always with this
If you heat the manifold the damper thingy will screw out you will need a good torch. What part is broke those damper thingy things are in demand. If you dont want to get it apart just get a new manifold they run around 100
