no fuel to the plugs
1st-rebuild
New User
1951 jd model m was just rebuilt, trying to start it and it's not getting gas to the spark plugs???? good compression at the plugs, timing is right ,gas comes out the air intake when choke is pulled but doesn't seem to go up {up draft} through the head. Everything's new or rebuilt. no blockages either.
(quoted from post at 16:07:23 07/22/14) sounds like the valves are adjusted too tight, not letting the piston pull in a rich charge of air mixture.
ir pulls hard on the carb when cranking it
Try a shot of ether. The gas is supposed
to be mostly just droplets by the time it
reaches the piston. It is actually the
fumes that burn and droplets have more
surface area so they give off more fumes
so it burns better, so you shouldnt see
any fuel.
Did you overhaul the carberator? Since it is an updraft carb it should have a venturie in it. Without it your engine will not pull/vaporize enough fuel to start the engine.
(quoted from post at 17:51:06 07/22/14) Did you overhaul the carberator? Since it is an updraft carb it should have a venturie in it. Without it your engine will not pull/vaporize enough fuel to start the engine.
bought a new carb and I set the needle valve and idle adjustment by specs I got off line for this model
Choke it until it pops. All updraft carburetors will have gas running out the intake if it doesn't fire in about two revs. gas running out doesn't mean that it is blocked or flooded.
(quoted from post at 18:09:32 07/22/14)
hen I choke it gas runs out the intake of the carb{because I have the hose off to the breather} in several seconds and flame will occur quickly but goes out so I shut the choke. it has popped on several occasions but nothing else. even after all this I pull the plugs and theres no sign or smell of gas even getting to them
Flame at the carb is very significant new information, indicating a probable timing problem. I would check to see that valve timing is correct, and like Teddy Food said check to see that spark is occurring on compression stroke and not 180 degrees out.
(quoted from post at 03:52:52 07/23/14)
Distributor is in the correct position, Both plugs spark just fine when I get off work today I'm going to tinker around with the valves
(quoted from post at 22:20:48 07/22/14)
Flame at the carb is surely a timing issue of valves way to tight.
Check all timing again!
(quoted from post at 05:55:16 07/23/14)
how do I loosen the valves, I had a machinist install the valve train and theres no adjustment only the screw on the rocker arms 2 to a valve of course, will that loosen them any?
