Sc CASE....NO Power!
Anonymous-0
Probably should post this on th CASE page, but here goes....Getting my SC running after sitting (inside) for about four years. Cleaned up mag points & contacts & now have spark. It starts good, but is very slow on throttle response & will barely make it up a slight grade in high gear. Just very sluggish. Throttle and governor seem to have proper travel. Also blew out all carburetor passages. Not sure what's wrong.
Glenn F.
Sat for four year good chance the rings are sticking so you need a simple ATF treatment
I sure appreciate your horse sense Old. I suppose it could be rings, but seems unlikely to me.
Wish you were 1000 miles closer.
Glenn F.
Any time an engine sat for over a year the ring tend to stick and since that happen I bet if you checked compression you would find it to be low
