Gehl CTL 60 track loader keeps cutting off
Grey
We have a Gehl CTL 60 track skid loader that will crank fine and runs about 15 seconds then shuts off. There is a light flashing on the console that looks like an oil light but not sure. I don"t have an owners manual for it. However I have checked all the fluids and filters and everything is good. I am sure it"s some sort of sensor or switch but I don"t know where to start.
I know some engines will shut down it they don't sense oil pressure for a set amount of time. 10-15 seconds sounds about right so it's possible that's what's happening here. Do you have any way to manually measure oil pressure? That'd be a good place to start.
Shut down system is coming on. Is it the third light down from the top? That is engine oil pressure/coolant level warning light. If so you need to find the bad sensor. There is sensors in either the bottom or top radiator hoses depending in serial number break. Oil pressure sensor is on the left side of engine.
Did you figure out your issue? I am having the same problem with my gehl ctl 60. Starts up but shuts off after 5 seconds. But if I keep cranking for a good 20-30 seconds it will start and run fine. Any ideas?
(quoted from post at 11:39:16 11/27/14) Did you figure out your issue? I am having the same problem with my gehl ctl 60. Starts up but shuts off after 5 seconds. But if I keep cranking for a good 20-30 seconds it will start and run fine. Any ideas?
ueI pressure is Ioosing prime when sitting overnight me thinks
