trailer brakes update
SDE
After cleaning the plug, at least one tire was sliding across-ed the yard when the brakes were applied. Tonight I jacked the trailer up and adjusted the shoes. Now they are all working. Unfortunately, I found that two of the tires have really bad inside sidewalls.
Thank you for the help.
SDE
It seems like this older equipment is like a can of worms. The more you dig the more you find. LOL
YOU at least figured out your brake issue. So you have one point to the good.
Just guessing, but I bet the tires with the bad sidewalls were on the right side of the trailer. Have seen that a lot from running on the edge of a narrow pavement.
