TractorLinks.com
Tractor Talk Discussion Forum
Re: Kubota AC Repair
jm.
07-10-2014 12:29:47
PSB Go right behind the seat little box that looks like a briefcase. Remove that cover and clean the filter. You are not moving enough air. Think that will solve your pressure problems since you have done such a good job on the rest. Most folks don,t have gauges and just do as you say your guys did and load the system without cleaning or checking anything. Let us know the results.
psbhouston
07-10-2014 12:48:04
 Re: Kubota AC Repair in reply to jm., 07-10-2014 12:29:47
jm
I have cleaned the evaporator and all of the cab duct work. What a mess. It is a poorly designed system that had leaks on the duct work on fresh air and recirculate systems. I sealed it all up with foil back tape and now only clean air is going thru it. It blows hard and there is a lot hitting you in the face.
For giggles - I blew out the condenser up front with compressed air. It seemed clean. But I decided to run water over it while the manifold gauges we hooked up.
The pressures dropped to 40 and 190 psi and the vent temp dropped to 62 degrees. I will let it all dry and see if it holds but I would bet the pressures head higher up.
The book calls for low side 21/28 and high side 185/242 psi.
will let you know - have to get the hay on the ground - but dont want to cook while doing it.
thanks for your advice
Greg
jm.
07-10-2014 14:56:41
 Re: Kubota AC Repair in reply to psbhouston, 07-10-2014 12:48:04
OK Been selling Kubota 30 years old 9000 series were a mess but your 40 series has not been troublesome at all. I think you have found your problem. The worst thing you can do is put water to the condenser. All those seed and dust turn to mud and swell. You solution now is to take small flat shipping strap and slide it thru the condenser and get back with the compressed air. Get the flow of air in there and your pressures are going to level out. The 65 deg discharge is not hardly there but something like 35 degrees below the outside temp is a starting place.
psbhouston
07-10-2014 12:47:41
jm
Greg
